Need a little help with crank damper
Old Jul 12, 2011 | 07:15 PM
rossi89's Avatar
Default Need a little help with crank damper
My lq4 is ready to be assembled and I need to buy a crank damper. It is going to be a turbo motor about 750whp. Can I use a stock damper? Would a damper off of a ls2 work? Where can I find the one I need? Thanks
Old Jul 12, 2011 | 08:08 PM
S10xGN's Avatar
As long as the offset is right, any GM damper should work just fine for a turbo application. AFAIK, there are only 3 offsets; C-5 = 0", F-body = +0.75", truck = +1.50" and several other "families" share one of these...
Old Jul 13, 2011 | 03:23 PM
rossi89's Avatar
Ok thanks!
