LS2 Cam Sensor
Old Jul 24, 2011 | 07:23 PM
Bulldog0082's Avatar
Default LS2 Cam Sensor
Im just trying to figure out where the Cam sensor is at, and if its difficult to replace. Thanks
Old Jul 25, 2011 | 06:16 AM
davidws6's Avatar
If you look at the front of the engine from underneath, it's at about 10:00 held in with a 6mm bolt. It's close to the water pump but should come out no prob. 3 wire connector.
Old Jul 26, 2011 | 08:03 PM
Does it matter if its a gto or corvette? bc i dont see it from underneath.
Old Jul 26, 2011 | 08:36 PM
TransWS6Am's Avatar
nope, doesn't matter, it's on the timing cover.
Old Jul 31, 2011 | 08:11 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Like Transam above showed, it is in the front cover, towards the driver's side of the cover. Why are you replacing the sensor? What symptoms are you experiencing?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 4, 2011 | 09:50 AM
For the past 3 months my GTO has had a problem of shutting off as soon as i turn it on.. it doesnt sputter or anything it just shuts off.. I have to set the alarm on then off then it would start. Now it doesnt start at all it just clicks like if the baterry is dead.. i have changed the battery and nothing.. still clicks like if it was dead.
Old Aug 4, 2011 | 10:13 AM
1320's Avatar
well, that probably has absolutely nothing to do with the cam sensor.
Old Aug 5, 2011 | 02:31 PM
I would bet against a cam sensor issue there. Do you have a "security" light lit-up on your dash gauges?
__________________
Old Aug 5, 2011 | 03:02 PM
1320's Avatar
hey matt, on a side note thanks for selling me cams awhile back.
Old Aug 5, 2011 | 03:03 PM
Glad to help
__________________
