Vacuum Hose
Old Aug 7, 2011 | 03:08 PM
2000dreambird's Avatar
Default Vacuum Hose
ok so i just swapped a LS3 into my 00 bird,
there was a vacuum line on the back of my LS1 intake for the climate control. however this vacuum hook up is not on the back of the LS3 intake so where do i hook it up too now????
HELP!!
Old Aug 7, 2011 | 05:28 PM
litle88's Avatar
Ohh damn!
I'll be in the same boat sooon!!
Bump up then!
Old Aug 7, 2011 | 09:33 PM
KENS80V's Avatar
There is a vacuum connection at the rear. It is right next to the large vacuum elbow for the brakes. In most cases it is sealed. You just cut the plastic tee from the end to open it.
Old Aug 8, 2011 | 01:40 PM
i did see that but was worried i shouldnt mess with it?
Old Aug 11, 2011 | 10:23 AM
1A Dan's Avatar
you could always put in a T back there off the big vac line too.
Old Aug 17, 2011 | 07:53 PM
Flame Arrow's Avatar
the ls3 stock intake should have a port from the back
when I installed the FAST102 there was no port in it, I need it for the engine vacuum pressure for my NPP mufflers
so what I did is making a T back and put it in the brake vacuum line
