I have had a lot of traditional musclecars with big cams, overlap, and all the characteristics that go along with it. This being my first LS motor, I wanted for once to show a little restraint in the cam department. I look at the LS different than the other motors I've had. I really wanted something that has big power, is really driveable, and did not have a huge lopey idle. That is what I have have had each time before, and even though my 466 Pontiac was EFI'd, it still was a little too over the top. I contacted Geoff at EPS because I did not want to guess on the cam. I told him I wanted an easy 600 HP, wanted a little lope to it, but not the tight LSA and overlap I had before. The 226/242 is correct, and necessary on the square port heads. The real important part of the equation was that I decided that I wanted to run catalytic convertors. I have grown tired of the smelly musclecar thing, and the big inch LS is the perfect way for me to make that much power, and still be able to get rid of the smell. At first I thought the cam was small, but after thinking about it and sticking to the plan, I did not second guess Geoff. He knows what he's doing. Also my car is heavy, so I need good low end power. I also did not want this motor to need to be revved to 7k. I told him 6500 is fine. I will be starting a build thread on this soon, and will post all of my dyno sessions, so hopefully everything will work well together. Thanks for the interest and advice.
