LSA Manifold to Cat Pipe Stud and Nut Size
I have the studs and they seem to be M10, but they are not 1.5 pitch (nothing SAE is even close). They seem to be slightly larger, but they are not 1.75 either. a M10 x 1.5 nut will only make a few turns and a M10 x 1.5 die isn't going to work either.
Any info or part numbers would be appreciated. Thanks!
The Studs are GM Part # 11589264 and they are M10 x 1.5 x 30/M10 x 1.5 x 16.
The nuts are GM Part # 11517996 M10 x 1.5.
