24x or 58x relutor?
Old Jun 6, 2012 | 07:24 AM
6togo's Avatar
Default 24x or 58x relutor?
I am putting together a LSX 427 and plan on using DBW which wheel do i need and i dont have the management system yet starting from scratch i may do a GM pcm or aftermarket depending on how my budget looks at the time? I cant seem to find the solid answer searching but most say a 58X but that could that be they have that system?
Old Jun 6, 2012 | 09:15 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
There were vehicles with DBW throttle bodies that had 24X as well as a lot that have 58X, so from a PCM/management standpoint, you could do either. Aside from parts availability if you're looking at used, salvage, or other second hand parts I have not seen any empirical data that shows one is any "better" than the other.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 6, 2012 | 03:28 PM
Gray86hatch's Avatar
I would go 58x the reluctor is a better piece. Will handle the rpm better than a 24x
Tim
Old Jun 6, 2012 | 08:35 PM
6togo's Avatar
So either will work but i would have more of a chance to find parts for the 58X is that right? More than likely i will be running a fast or big stuff system when funds permit!
Old Jun 7, 2012 | 10:30 AM
Tim
Better piece I could almost agree with, being it is a single wheel with no need to have them welded together to ensure they do not split. Handle RPM's better, I could argue either way.
__________________
Old Jun 7, 2012 | 10:31 AM
Yes and no...the 24X stuff was made for about 10 years, whereas the 58x stuff has only been around for about 5 or so. But, a lot of the 24X stuff ahs been wrecked, destroyed, etc. The 58X stuff on average is likely in a bit better condition.
__________________
Old Jun 7, 2012 | 02:26 PM
6togo's Avatar
Sounds good thanks for the input now I just need to get the dragonslayer crank which I been told is not available until the end of July!
Old Jun 7, 2012 | 03:39 PM
ws602's Avatar
late model engines have a billet 24 tooth wheel that they can put on your crank for you .Call them and Brian can explain the process i just had them put one on my crank.
