05 LS2 internals in a 07 lq4 block?
Old Jul 17, 2012 | 12:34 AM
85coupe366's Avatar
Default 05 LS2 internals in a 07 lq4 block?
can i use the full internals from the LS2 in my 07 LQ4 , reason asking is hes going all forged build an is not gonna use the ls2 stuff , how much can i shave off my stock 317 heads an be safe
Old Jul 18, 2012 | 10:43 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Safe for milling heads depends on cam specs and gasket thickness as well. Do you know the rest of the combo yet?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 18, 2012 | 11:27 AM
85coupe366's Avatar
I was wanting to use all the stock stuff from the LS2. Cam , crank,Rods pistons and oil pan. He is using just the block and heads and is gonna sale/ give me the stock stuff. I just didnt know if it would work in my block going 05 to 07 . This being my first Time dealing with a LS base engine thanks in advance
Old Jul 20, 2012 | 10:39 PM
85coupe366's Avatar
took the windage tray off tonight and its more than just a spun bearing. the crank is broke at the #4 cap so full build is the plan now .
Old Jul 24, 2012 | 06:36 AM
85coupe366's Avatar
Can anybody answer my ? About internals please
Old Dec 28, 2012 | 02:27 AM
85coupe366's Avatar
05 LS2 and 06 LQ4 internals interchangeable ?
