problem wiring the dash gauges
Old Sep 10, 2012 | 10:24 AM
my2001beast's Avatar
Default problem wiring the dash gauges
someone please help,I purchase a 525HP LS3 engine with install kit from GM performance a friend and I have installed it into my 2001 Trans Am we have been able to get it running but don't know where to tap into the wiring for the gauges the friend said something about them running off class 2 serial data line just where do I find this such as wire colors and locations if possible could someone post the wiring diagrams as I am lost. while I am posting might as well relate another problem, I bolted on the transmission bolted up the tourque converter started the car dropped it in gear NOTHING HAPPENS checked the fluid level it is ok tried again and still the same thing what gives.
Old Sep 13, 2012 | 10:09 AM
Default still need help with gauge wires
please I still need help 87 people have viewed this problem and have left 0 replies or suggestions,is my TA going to become a paper weight in the garage
Old Sep 15, 2012 | 12:20 AM
soundengineer's Avatar
need to know what pcm you are using...
Posted from LS1Tech.com App for Android
