Water Pump
Old Dec 7, 2012 | 09:28 AM
Gordon0652's Avatar
Default Water Pump
Hello,
Still building my LS7 440 engine seen in my sig. I will be using all my F-body pulley accessories set up and I am now looking for a water pump. If i buy pump "19180610" will that line up correctly with my belt?
http://paceperformance.com/i-6251476...-2010-ls7.html
For some reason I am thinking I have to but the stock LS1 F-body pump so it all lines up.
Thank You!
Old Dec 7, 2012 | 10:55 AM
garys 68's Avatar
That pump is spaced for corvette accessories. The 98-02 f body accessories, crank pulley is about 3/4" farther out. You'll need the f body pump.
Old Dec 7, 2012 | 12:02 PM
Gordon0652's Avatar
Thank you for the reply. Can the LS1 water pump work with an LS7 block? Hope it flows enough for this motor and can handle the RPMs.
Old Dec 8, 2012 | 07:18 AM
garys 68's Avatar
Not sure if there's much of a difference in water pumps. Same pump used on 4.8 to 6.2 trucks. Lots of big cubic inch strokers using stock pumps.
Old Dec 8, 2012 | 07:53 AM
Gordon0652's Avatar
Thank You Sir!
Old Dec 9, 2012 | 06:30 PM
marc.madmax's Avatar
I don't know specifically the ls1 but I have a LS6 in a 04 CTS-V that I replaced the water pump from an 09 LS-7 with no material changes. I have converted the plumbing for the heater lines but that I know has no bearing on your questions.
