LS1 PCV on LS3 top end.....
Old Feb 10, 2013 | 05:41 PM
USMC5811's Avatar
Default LS1 PCV on LS3 top end.....
i'm struggling to figure out how to hook up the PCV (i think thats what it is) The hose with 3 fittings on it. 1 for the back of the drivers side valve cover, 1 that is supposed to go on the back of the passenger side valve cover (i do not have this anymore as i switched over to an LS3 valve cover) and the 3rd part of the hose has the ground wire which connects up by the throttle body. What provisions do i need to make to make this fit or work with my setup?
Old Feb 10, 2013 | 10:57 PM
DietCoke's Avatar
Run a late ls6 or ls3 valley cover with the crank vent out of the valley cover and run pcv like the ls3s do
Old Feb 11, 2013 | 07:21 AM
USMC5811's Avatar
would you happen to have a link or picture to what i need?
Old Feb 11, 2013 | 07:31 AM
lemons12's Avatar
http://ls1howto.com/index.php?article=18
