New block vs old (seasoned) block
Old Feb 14, 2013 | 09:30 AM
6t9camaro's Avatar
Default New block vs old (seasoned) block
Hello just a quick questions to get some thoughts on this. I'm looking at buying a forged ls3 engine and I'm dealing with two high end builders and one wants to build using a used block and cyl heads as all core shifting is done as its gone through heat cycles! Now the other builder says no way never build off a used block and will only use all new parts! (Block, heads) which way to go???
Old Feb 14, 2013 | 10:13 AM
DietCoke's Avatar
Used block, new block, whatever. Once theyre cleaned and finish machined, i couldnt tell the difference
Old Feb 14, 2013 | 10:24 AM
cbruer's Avatar
I would go with the new block always you know exactly what you have.
Old Feb 14, 2013 | 10:26 AM
cbruer's Avatar
And that builder knows if he starts with all new parts its a less chance for a customer coming back with a frown on his face.
