Help Needed My Car Is Running Rough And Stalls
Old Mar 2, 2013 | 02:43 AM
waynes95Z28's Avatar
Default Help Needed My Car Is Running Rough And Stalls
i just got this car a few weeks ago ill tell you everything i know about it.
its a 1995 CAMARO Z28 LT1 M6 411 gears msd 6a hooker headers no cats
bbk throttle body. it does have a cam and rockers. not sure of size but sounds ok not to big of a cam. and i think their might have been some head work on it. new opti just installed.
ok here we go.
i test drove it a few weeks ago. it was bogging running rough then it would just go ok. i drove it on the freeway and it ran a little rough but still felt strong. next day i drove got on it, left off then it died. now it starts but runs much worst. and after a few minutes it dies and wont crank ? also it has a funny squeeky noice. so we drained the oil. and it looked like their was some flakes im guessing spun bearing. again its start runs rough for about 5 minutes then dies out and won t start no cranking until it cools down
any help would be great.... god bless
Old Mar 4, 2013 | 09:46 AM
LSnights09's Avatar
Probably a multitude of problems between not cranking and then dying. Flakes in your oil is a bad thing. I'd start with a compression test. And make sure you're running good fuel in it.
Old Mar 5, 2013 | 12:20 AM
running good fuel. cant get a compression test right now. but my main thing is why would it crank at normal speed start fast (normal) run for a few minute die out and then either barley crank or not crank at all. until it cools off ?
Old Mar 5, 2013 | 02:34 AM
DietCoke's Avatar
because it's an lt1.
Old Mar 12, 2013 | 06:44 PM
jdub38672's Avatar
Pull the motor before you ruin anything else
By Brett Foote | 2026-06-04 05:00:17
