New build help!
Old May 6, 2013 | 07:44 PM
Chi_weezy's Avatar
Default New build help!
Hey guys, I've been researching every day for a few weeks now regarding Ls motors, heads, intakes etc etc. I've learned a bunch. But it's never enough
I have a 6.0l lq4 with some ls1 parts. It's putting down 273rwhp/317tq in my 97' 240sx. I want to make more power. Around 400-450rwhp
Can someone please chime in on the best package of heads + valve train, intake + TB, and cam? This will be a street car with some occasional drifting. Not a dd but I'd like it to be driveable with good start up, idle etc
I want the L92/LS3 heads (Bare, they are the same). But I need to choose springs, retainers, push rods, rockers, and anything else that I need for a complete head set up. Should I buy the LS3 assembled heads for the hollow valves and stiffer springs, or go with the L92 heads for a little cheaper with the solid valves and softer springs (I figure ill have to replace the Ls3 factory springs anyways?)
I know I need the LS3 intake mani but am not sure about what size or brand throttle body
And lastly, I've read all the threads on cams and still not sure if I should go with the great TR224, something different, or trust a vendor to grind a custom one for me. I also dont want any piston to valve clearence issues. So much to learn! So please if someone could be so helpful to give me a complete setup of the best bang for buck parts for my I\H\C\TB build it would greatly help me out !
Old May 7, 2013 | 07:36 AM
Blackpanther99's Avatar
Ill go with the L92 heads, lots of people have goodluck with them. Along with with L92 heads you will need a LS3, LY6 or a L92 intake with a cable driven throttle body. You can use a FAST 92mm or a BBK throttle body as well, just make sure its a 4bolt. I suppose the 224r is good enough for your build. TSP (Texas Speed) has the whole package I believe. Thats unless you want something bigger or custom hit up Martin @ Tick Performance.
Old May 7, 2013 | 07:59 AM
akCamaross's Avatar
Just use stock motor if it is still in good condition. TU2 Cam. L92 heads. Holley high-ram intake manifold/ or ls6 manifold.
Im doing a lq4 with a single pt88 turbo build and doing alot of the same.
Old May 13, 2013 | 09:48 PM
Chi_weezy's Avatar
Guys, I see everyone is recommending the L92/Ls3 heads for my Lq4. TSP recommended the PRC Stage 2.5 5.3l heads due to the fact that they'll increase my compression ratio to about 10.6:1 vs 9.6:1 with the L92.
The argument there is that the 5.3's will yield higher compression, a more responsive and efficient motor, and better power under the curve, more torque down low etc. and that the l92/LS3 will yield higher peak power up top.
Can anyone chime in on this?
