Bosch part #'s for E85 injectors
Old May 9, 2013 | 08:08 AM
speedshifter's Avatar
Question Bosch part #'s for E85 injectors
Hey guys, tried this over in the fuel forum, but its a ghost town over there.
I'm looking for the Bosch 10 digit part #'s for high flow LS3 style injectors. Looking for something 80lb or larger @ 58psi. I have a lead where I can get a discount on Bosch injectors, but I need the 10 digit part #. I have spent hours searching on the internet and there is a lot of BS info out there.
For instance, one website will say a #0280158187 is a 103lb injector @ 58psi (4 bar), but if you google that # it comes up as a stock LS9 replacement injector at O'Reillys auto parts which is only a 52lb injector.
I also found several sites saying the #0280158051 injector is 80lb @ 58psi, but that comes up as a stock 42lb LS3 injector.
I have seen the # 0280158040 floating around as an 85lb @ 3 bar injector. However, its got a long metal nozzle on the tip. Will that work with an LS3 intake?
Could really use some clarification here. Trying to build a LS3 stroker on E85, hence the need for a high flow injector. Will be running twin Bosch 044 pumps.
Thanks.
Old May 14, 2013 | 08:44 AM
sometimes this forum is like talking to a wall...
Old May 14, 2013 | 09:50 AM
DietCoke's Avatar
Wrong forum for that kind of question, tbh. The long tips dont cause any issues... they actually help distribution in most cases. I'd call fuel injector connection. They stock and sell these
Old May 16, 2013 | 08:56 AM
I know its technically the wrong forum, but not getting any replies in the fuel injection forum.
