5.3 LC9 Questions
I'm buying a 5.3 LC9 for a 67 Firebird project, I'll be mating it to a GTO 6 Speed (MN12). I have the engine coming with original wiring and ECM (E38), my issue is this, I'd like to delete the AFM and DOD which I understand what needs to be done, however, I'd like to run the VVT but with a better cam, another issue is the 58X and E38 ECM, I cant run a DBC unless i install an TRG-002 Box from Lingenfelter... but again, then I lose the VVT. Can i swap to a regular LS cam, ditch the VVT and still run the converter or retain it?? Any suggestions/advice? Engine is out of a 2011 avalanche Auto, needs to be reflashed/tuned to manual set-up as well.
Also, i started reading up on the E67 ECM's (capable of DBC and DBW).... thoughts?
Thanks!
I think I read that the DOD should be removed if running a hot rod. It also doesn't work well with manual transmissions. The DOD removal is more involved since the heads have to be removed.
Finally, I think you can run a DBC with a 58x reluctor. I just bought a Holley DBC throttle body. The Holley Avenger ECM has an LS2 version. It will work with 58x, but it won't work with DBW. The Holley Dominator is needed for DBW.
This is what I've learned so far. Feel free to double check my research and correct me if I'm wrong. I have an LC9 5.3L, and it will eventually go into a 84 firebird.
