823 Head... what to look for when buying used.
Old Aug 4, 2013 | 07:56 PM
biohazardbill's Avatar
Default 823 Head... what to look for when buying used.
I have a line on some 823 heads that the seller says is from a blown LS3 engine. What should I look for other than just the casting number to verify they are LS3, or should I not even care? Says it is from a 2010 Camaro.
Old Aug 5, 2013 | 02:11 PM
allan808's Avatar
Ls3 heads are 821, l92 heads are 823! The only differance between them is the ls3 has lighter intake valve. Just pull the heads and look to see any damage , if there are no bent valves or damage in the cylinder ur good.
