run problem
Old Aug 7, 2013 | 08:15 PM
henro's Avatar
Default run problem
I put a 2003 5.3 and 4l60e in a 57 chev It runs but has a low idle and stumbles when you accelerate . motor set for 2 years but has no codes in computer has new fuel pump but has 43 lbs until I undo the vacumn at regulator then goes to 47. Has new fuel regulator new iac valve ,new throttle position sensor
Old Aug 8, 2013 | 06:36 AM
davidws6's Avatar
Could be anything. Knock sensors to O2's . Your going to have to scan it with an O2 sensor to see what's going on. I think the fuel pressure should be 58psi
Old Aug 8, 2013 | 10:23 AM
LS1MCSS's Avatar
Do whatever you have to do to get the fuel pressure up to 58lbs and then see how it runs.
Old Aug 8, 2013 | 10:51 PM
allan808's Avatar
Needs to be 58lbs or itl run like ****.
