AC 5v hotwiring
Old Aug 19, 2013 | 01:23 PM
sowaidi's Avatar
Default AC 5v hotwiring
I couldn't ind out the roblem I was having with my AC going on and off. I decided to hotwire the compressor with a relay kit. Problem is I can't find 5 pin 5v relays. I've heard of electronic thermostats but don't know iif they'd be a solution.
Old Sep 2, 2013 | 03:22 AM
sowaidi's Avatar
Come on guys. Anyone?
Old Sep 2, 2013 | 03:50 PM
Red99ws6's Avatar
Hey man have you checked your hi low pressure switch that's what mine did and changing that switch fixed my prob
Old Sep 21, 2013 | 12:07 AM
man-o-war's Avatar
Your problem is the ac compressor clutch air gap. Google it, you will need a new clutch or maybe you can remove washer fro M under the clutch shaft and get air gap back in spec?
