What nitrious plug are you useing ?
Old Aug 22, 2013 | 10:56 AM
booboo37's Avatar
Default What nitrious plug are you useing ?
I biult a ls3 with the GM cnc 821 heads with upgraded aftermarket exhaust valves.........this is a carburated motor with the front mount distributor.......its running great on motor with pump gas with tr55 plugs but i just put a 175 shot on it and i`m woundering what nitrious plug i should use...??? Also should i run some 110 race gas ?? 11.5 compression....
Old Aug 22, 2013 | 11:18 AM
Carter01's Avatar
For a 175 shot i would not go any hotter than a br8ef.
Old Aug 25, 2013 | 07:02 AM
booboo37's Avatar
thank you sir and i was thinking the samething..
Old Sep 24, 2013 | 10:12 AM
booboo37's Avatar
Also what should i gap the plugs at ??
