lsx 454 induction
Old Oct 22, 2013 | 07:41 AM
rrandp88's Avatar
Default lsx 454 induction
New to the ls motors. Building a pro touring 66 chevelle and wanting to do a GM crate lsx454 (i know their are better options but am getting a deal on the crate).
It does not come with any induction. I want to run the gm cast intake with a fast ez efi 2.0 with a custom air cleaner and hidden coils to keep it clean and look like a old small block. I do not want to run fuel rails either.
Running a t-56 so i do not need any trans controller.
What all is needed to run the Fast 2.0 system?
What do i need to run the ignition system?
Thanks, any input would be greatly appreciated. This is the look i am shooting for.
Old Oct 23, 2013 | 04:10 PM
Summitracing's Avatar
LS1Tech Sponsor
That is a great look for the LS engines in the classic muscle cars!
The FAST EZ-EFI 2.0 Kit includes everything you would need for up to 1200 hp including the fuel pump, regulator, etc. and is a great option.
As for relocating the coils, you can use the Proform coil relocation harness. You will just need to determine where you are mounting them, make a bracket, and you can use the MSD Univeral LS wire set
Hope this helps with your project.
__________________
800-230-3030
www.SummitRacing.com
Old Oct 28, 2013 | 08:40 AM
rrandp88's Avatar
Default ignition
Thanks for the reply. Will the fast system run the ignition as well? or do i need to use an ignition box like the msd 6ls?
Old Oct 28, 2013 | 01:42 PM
LS1Tech Sponsor
I have sent a PM with some more information for the LSX.
__________________
800-230-3030
