External oil pump question
Old Jan 30, 2014 | 12:50 AM
Bill71's Avatar
Default External oil pump question
I am going to use a 4 stage external oil pump on an LS7 block. I already figured I will have to tap and plug the oil gallery hole under the front cover. I plan to run a remote oil filter and then connect to the block. What are my options for connecting the pressurized line to the block and will I need to modify the block if I use AN10 fittings?
