ls3/ nick williams question
Old Feb 17, 2014 | 05:15 PM
N/A86's Avatar
Default ls3/ nick williams question
hi, i am almost done with a 408 build for my camaro, i am using stock un ported ls3 intake manifold for now and need to buy a dbc throttle body and was wondering if the NW102mm would work? and would it hurt the flow having such a big throttle body on stock manifold? reason beeing is they seem to be roughly the same price and i plan on upgrading the intake eventually down the line, thank you.. adam
Old Feb 18, 2014 | 12:09 AM
TURBO BUICK's Avatar
I may be wrong but I don't think that the stock LS3 manifold has a large enough throttle body opening to accept the Nick Williams throttle body. You would have to go with the F.A.S.T. 102 manifold.
Old Feb 18, 2014 | 12:38 AM
Baconz28's Avatar
I'm not sure about running the 102 mm throttle body on the ls3 intakr. I have a 92mm nick williams throttle body. It's go be the drive by cable. You will need this bracket from ws6 store. http://www.ws6project.com/user_stor/...oducts_id=4692
Old Feb 18, 2014 | 09:41 AM
N/A86's Avatar
Thanks guys , so the 92 nick Williams worke on your ls3? Ill def buy this bracket to thanks for the link
Old Feb 18, 2014 | 09:57 AM
Baconz28's Avatar
No problem. I just ordered my nick williams throttle body from Brian tooley for my ls3 intake. Yes the 92mm will work
Old Feb 18, 2014 | 10:30 AM
N/A86's Avatar
That's actually where I was looking to, thanks
