Help! Broken plastic channel on valve cover!
Old May 11, 2014 | 01:58 PM
thaGrimace's Avatar
Default Help! Broken plastic channel on valve cover!
I took my valve covers off for a basic clean/polish, and due to some extreme stupidity and bad luck, one of the plastic channels inside the valve cover broke. It's still attached, but the hole that's visible in it is about double its original size now :-(
Also, on the other channel, one of the metal tabs holding it in is missing. Again, the piece of plastic is still secured in there, but it wiggles a bit.
I'm quite the noob when it comes to this, and I don't even know what the proper name for the piece in question is. Any info would be greatly appreciated. I'll post pics when I get back to a computer... I'm on my phone at the moment.
Thanks!
Attached Thumbnails Help! Broken plastic channel on valve cover!-1399834759091.jpg
Old May 27, 2014 | 08:33 PM
Hardcoresoldier's Avatar
Those are your PCV system baffles. I cut mine completely out and capped the port on both valve covers. I put a breather cap in their place
