L76 accesories
Old May 25, 2014 | 11:34 PM
98onyxss's Avatar
Default L76 accesories
For an avalanche L76 does anyone know if the accessories are the same as any other truck gen4 setup? Or are they specific to the L76? Ive read that everything is spaced out, and I've read that it's set back .75". Is the water pump setup to clear the vvt valve cover and keep the pulley in the same position, or does it use a different crank pulley too?
Old Jun 7, 2014 | 05:29 PM
Jimbo1367's Avatar
They should be the same.
