lq4 6.0 engine swap
Old Jun 28, 2014 | 08:53 PM
smokeyy_02's Avatar
Default lq4 6.0 engine swap
I gt a 2002 trans am and I was curious if I could take te 6.0 out of a 2500 hd and put it in my car will it bolt up to my t56 transmission and any tips on what all would need to be done to make this happen. any advice or suggestions would be helpful thanks.
Old Jun 29, 2014 | 01:29 AM
LLLosingit's Avatar
It will work depending on the year of the 6.0, you need a Gen 3 6.0 with a 24x tooth reluctor wheel on the crankshaft. You'll need to swap over the intake/ Drive accessories/ water pump/ coil packs / Oil Pan and pick up but everything should drop right in.
Old Jun 29, 2014 | 10:21 PM
smokeyy_02's Avatar
well I'm looking at one that come out of a 2005 model truck. would that work? I was thinking there was a kit you could buy or something to change that out if it wasn't the 24 tooth count. but thank you for the response it's very generous ��
Old Jun 30, 2014 | 07:14 AM
garys 68's Avatar
The 05 should be 24x, you can tell by the color of the crank sensor.
There are 24x to 58x converters too {Lingenfelter?)
Old Jul 1, 2014 | 10:02 PM
smokeyy_02's Avatar
do you know what color I should be looking for for it to be the 24x?
Old Jul 3, 2014 | 06:58 AM
garys 68's Avatar
Do a search here for black vs gray crank sensors.
Old Jul 11, 2014 | 02:22 PM
bugy's Avatar
for 24x you will need black sensor
