5.3l used engine oil pressure issue
Old Jul 9, 2014 | 12:47 PM
gthom's Avatar
Default 5.3l used engine oil pressure issue
I just installed a used engine in a 2007 Yukon it's a 5.3l engine.. Sounds great runs and drives fine. While driving the truck with in terminating lose oil pressure from 45-55 to 0-5psi both with the gauge or scan data. The engine still runs fine after it drops to 0-5 psi. So I pulled the intake and installed a new sensor, it still has the same problem.. Any suggestions?
Old Jul 16, 2014 | 04:37 PM
LS1MCSS's Avatar
Take it back where you got it.
Old Jul 16, 2014 | 11:17 PM
LLLosingit's Avatar
Did you install an oil pan and pick-up tube when you did the swap or did you use the one that came on the replacement engine? If you replaced it, It would make me wonder if there is a problem with the O-ring or pick-up tube/position.
Old Jul 17, 2014 | 08:15 AM
spy2520's Avatar
Is it based on temp? pressure relief bypass stuck? If its really intermittent and random it would seem like an electrical problem.
Old Jul 17, 2014 | 09:44 AM
rennat_2006's Avatar
There is a little screen underneath of where the oil pressure sending unit s rews in that gets gummed up and will restrict/cutoff flow to the sending unit. Remove the sending unit and use a litfle pick or similar fo pull it up and out of there.
Bad thing is that isnt always the issue either. Ive got a 07 5.3l burban that i replaced all of the lifters in it in april because it had one of the dod lifters go out on it and it just came back to me with a miss and oil pressure problems again. It was doing exactly what you described before replacement.
