Replacing intake\windage tray gaskets - any tips\tricks?
Anything I need to keep in mind, look out for, be aware of? Any tips or tricks that'll help?
Thanks!
The seals really needed to be replaced for sure. Is all this oil blowby, or a PCV problem? I have a small filter on the PCV line on the pass. valve cover. Its not plumbed to the air inlet like factory.
The valves and stems looked OK, as did the port area around the valves...but the oil was all around the openings where the intake seals.
Getting into the intake needs to be addressed...where do I start?
