Timing maps
Old Aug 14, 2014 | 09:23 PM
dfhdfw's Avatar
Default Timing maps
I have a 2008 4.8L LS engine. I am trying to build a ECU from scratch using a micro controller. I have the ignition and injection working in a test config (using a function generator as the CKP and a logic analyzer to monitor the signals). Before I hook it up I wanted to write the mapping algorithms. However, I'm not sure what to plug into the break-points. I am currently using a linear function. No real mapping to speak of. Where can I get the proper info for a 4.8L?
Thank you.
Old Aug 31, 2014 | 01:26 PM
Mercier's Avatar
Post in the tuning forum:
https://ls1tech.com/forums/pcm-diagnostics-tuning-7/
Good luck.
