clearance issues....uhoh!!
Old Oct 6, 2014 | 07:43 AM
metcalfm45's Avatar
Default clearance issues....uhoh!!
I'm having clearance issue with this Gen IV 6.0L motor and the Gen III 5.3L heads. Heads are untouched as far as milling goes. When the heads are set in place the motor turns fine. (No rockers attached) when I put the head bolts in, and run up by hand til they quit turning, the motor won't turn. Acts like the piston is hitting the head. Not a cool situation to have. Any suggestions? Or any experience with this? Any experience with a new Gen swap to replace a Gen III motor?
Old Oct 6, 2014 | 08:35 AM
KCS's Avatar
KCS
Moderator
Are the headgaskets on when you do this? If so, what headgaskets are they?
Old Oct 6, 2014 | 11:24 PM
metcalfm45's Avatar
Yeah they're on. They're stock height felpro gaskets.
Old Oct 7, 2014 | 06:31 AM
KCS's Avatar
KCS
Moderator
Stock for what engine? The 5.3L gasket will be an issue if that's what you're using.
Old Oct 7, 2014 | 08:03 PM
metcalfm45's Avatar
Stock 5.3l I had the gaskets checked onand they all "checked to be the same" 5.3, 6.0, etc. I was going to put some 6.0 gaskets and see what she does.
Old Oct 7, 2014 | 08:09 PM
KCS's Avatar
KCS
Moderator
Take the head off and look to see if the head gasket bore is smaller than the cylinder bore.
Old Oct 7, 2014 | 11:39 PM
LLLosingit's Avatar
He had another thread going with the same question and my answer almost mirrors yours, I also think it's the 5.3 gasket on the 6.0 bore that's causing the issue.
https://ls1tech.com/forums/generatio...ggestions.html
Old Oct 8, 2014 | 06:30 AM
KCS's Avatar
KCS
Moderator
Yeah I don't see how it could be anything else, unless there's more to the story.
Old Oct 8, 2014 | 10:02 PM
metcalfm45's Avatar
As soon as I get home on the 14th I'm gonna check that. Never thought of that. I've buit a 6.0 before and never had this issue.
