Cam and Valve Spring Recommendations
Old Nov 13, 2014 | 12:54 PM
CORYSTA's Avatar
Default Cam and Valve Spring Recommendations
I've done some searching and read the technical threads. I'm a Mechanical Engineer and I'm not afraid to say I don't understand most of it well enough to make this decision on my own.
The car is my DD. So I'm just looking to open her up, keeping a smooth ride/idle not drastically dropping my mpg, while still having enough torque to have improve throttle response on the street and enough horsepower gain to be able to take her to the track. If this combination is possible.
My Setup
02 Trans Am WS6 w/LS1 mostly stock
Kook Long Tube Headers withOUT Cats and Y Pipe
Voolant Cold Air Intake
Stock LS6 Intake - Emissions crap has been removed
I intend to upgrade to the Fast 92mm within the next year.
I just picked a set of low mileage 243s off of a vet w/ new LS2 Valves
I still need to get them to the machine shop to be looked over, cleaned, milled, and maybe a light hand port. Any advise on milling and porting would be appreciated! (I understand most benefits of porting are at high RPMs. That's about it.)
Obviously I intend to change the cam and add the springs when I change the heads.
Oh and I'll put installing new LS7 lifters during this and intend to upgrade my stock lifters with the comp cam trunion upgrade.
Old Nov 13, 2014 | 12:56 PM
CORYSTA's Avatar
I called comp and asked for their advise. I appreciate the advise the guy gave, while it was probably great advise it seemed like he was reading off of a sales sheet and had no experience with LS Engines. Which is why I'm here, I'd really like some advice from you guys who play with LS engines and/or have ran my setup.
This is what he suggested.
extreme 269
54-414-11
XFI™ RPM, XR269HR Great Mid-Range w/ Superior Top End Power, Needs Computer Modifications
With
valve springs
26915
GM LS Beehive™ Valve Spring Kit
Old Nov 13, 2014 | 01:54 PM
CORYSTA's Avatar
And this was put in the wrong forum. Mods please delete.
