Best oil filter LS3 418 cid
Iam asking about best oil filter # AC Delco or any else better than ? my application is LS3 418 cid with ls1 camaro ss oil pan also what is the best oil ? Actually i running AC Delco #46 with Castrol GTX 20-50 SAE and after car warm am get a poor pressure only (quarter gague) when i press pedel it wil come 3 quarter !!!! I think a issue from oil or the filter if any better can advice me !??
A little hard to find tho, so the next best filter is the Royal Purple followed by the Mobil 1 Extended filters.
After that, K&N, Hastings and Wix/CarQuest are all very good filters. Napa Gold is also decent.
I'd stay away from ACDelco filters and avoid Fram like the plaque.
Now, onto your oil and your oil pressure.
20W-50 oil is too heavy. I wouldn't go heavier than 10W40. Try a lighter grade along with a better filter and see if your PSI improves.
Although.....I'm thinking along the same lines as you.....and doubts that his builder would actually direct him to use 20W-50
KW
2nd. the pressure. The factory gauge is an estimate gauge at best. If you have a built engine, you should have some type of reputable after market gauge to read. All a factory gauge shows is it has some sort of pressure. Whether it has numbers on it or not, it's a guesstimate gauge.
Step up to a Wix, K&N or Mobil1. There's better but these are always well made quality filters.
