Harmonic balancer spacing
Old Jan 2, 2015 | 02:06 AM
jesh462's Avatar
Default Harmonic balancer spacing
I'm finishing up my swap and at the point where all I need to do is put on the accessory drive and wire up the engine.
Vehicle is an e36 m3 and as such I have to stick with the GTO/fbody layout. This is because my ABS pump has been relocated to the frame rail and would interfere with an alternator up high.
My question is: Can I use this harmonic balancer?
They only have one part number for LS applications. According to info I found on Holley's site, there is 3/4" difference between the corvette style harmonic balancer and the fbody style. Does this mean the TCI I linked will only work with close mounted corvette style accessory drives?
Old Jan 3, 2015 | 07:23 PM
S10xGN's Avatar
That TCI balancer is for a 'Vette and will not work. As you saw from your second link, the F-Body sets out 3/4" further. Should be easy to find an F-Body part...
