Ss trailblazer not starting
Old Jan 3, 2015 | 11:18 AM
randepandy's Avatar
Default Ss trailblazer not starting
Hey guys here is my dilemma. I bought a 2006 ss awd trailblazer just recently and now it won't start. It started out one day when I was leaving the gym and on first try it cranked but didn't start. Turned it off and started right up the second time but on the way home I noticed that my temp gauge did not move at all and was stuck in the cold position. I stopped for gas on the way home (had a half tank of gas in it) and when I went to leave same issue again. This time I had to push the gas pedal down to get it to start and just drove it home. There are no cel lights up but did a scan anyways and could not find any codes. could the engine coolant temp sensor be the culprit? Just figured that would throw a code though but was just kinda odd that I noticed the temp gauge not moving. Any help in pointing me in the right direction would be helpful. Thanks.
Old Jan 5, 2015 | 06:31 AM
homemade87's Avatar
The trailblazers have a history of bad ignition switches. There is a updated switch they have to replace the old style . Its a good chance that's your problem because of the fail rate . It would be a good idea to change it anyway so it wont leave you stranded someday. Go to tbssownwer.com . You will find plenty of info . Even has a wright up on how to change it . Also a video on YouTube.
