Changing from LS1 to 6.0L; bolts on???
Old Jan 12, 2015 | 07:23 AM
Mike Cordero's Avatar
Default Changing from LS1 to 6.0L; bolts on???
I'm in the way to replacing the LS1 short block to a 6.0L iron short block. My questions: Can I use the LS1 intake manifold on the 6.0L? what about my LS1 heads on the 6.0L? and what about using the LS1 water pump with all the LS1 front engine accesories on the 6.0L?
Old Jan 12, 2015 | 10:42 AM
99z28383's Avatar
Yes, everything will bolt up except you will need to drill and tap for the other alternator bolt. Some people just go without and say it's fine, but to each his own.
Old Jan 12, 2015 | 10:57 AM
So the intake, heads and water pump will fit with no prob.? Because I'll be using the F-body front engine accesories, I'll use the LS1 damper?
Old Jan 13, 2015 | 09:48 AM
99z28383's Avatar
Yes, you will have to use the ls1 damper as well.
