5.3 swap rough idle
Old Mar 2, 2015 | 11:24 PM
Dusty1's Avatar
Default 5.3 swap rough idle
Hey guys new here did a 5.3 swap on a 98 c1500. Fires up and runs smooth for about 2 min the starts getting real choppy. Change the injectors,fuel regulator,coil packs, intake gaskets, head gaskets, maf, o2 sensors, pcv, and still does it. Please help
Old Mar 3, 2015 | 12:48 AM
Tuskyz28's Avatar
Have you had the 5.3 tuned accordingly to your swap ?
Old Mar 3, 2015 | 12:59 AM
Dusty1's Avatar
When I had the harness built they made me a fused harness. He also flashed the computer and put what he called a 87 tune on it. Other then that nothing else
Old Mar 3, 2015 | 01:31 AM
Tuskyz28's Avatar
Strange deal.... have you replaced the throttle position sensor? Is the throttle body nice and clean?
Old Mar 7, 2015 | 01:40 PM
Dusty1's Avatar
Ya I cleaned it and checked it check out good. I have a question. Having trouble with my swap. Truck fires up good but then starts to idle rough and it's throwing a misfire code. P0300 witch is a random misfire changed all the injectors checked for spark good spark. Did a noid light test on the injector wires and its pulsing but very very weak can this be a problem with the ECM? Maybe a bad tune? It starts happening when it warms up. Thanks
