need help with an initial timing curve
Old Jun 9, 2015 | 06:29 PM
wes1980's Avatar
Default need help with an initial timing curve
I have a 2009 lq9 engine that has the vvt delete,msd 6012,comp cams .625 lift cam an intake and a pro systems 780cfm carb also a th350 Trans and 410 gears with a 26inch tall tire in a 1989 camaro. I'm not sure how aggressive I can get with the timing and how to set the map sensor up in the box. if anyone would take the time to walk me through this I would really appreciate it
