Finalizing build
Old Jul 8, 2015 | 01:17 PM
Wesley Jack Land's Avatar
Default Finalizing build
Never posted on here mainly post on performancetrucks.net but they arent any help on my last questions before i wrap up my build so I thought I would try here if you dont mind, my appologies before hand cuz i know this really isnt a truck site, its a 2000 chevy single cab with a LQ9.
I have my LQ9 with the new cam, oil pump, timing chain, LS3 intake, and LS3 heads built adn got it in my truck this weekend. Last couple questions if anyone can help:
Well my stock passenger side valve cover from LQ9 wont work, hits rocker arms. So decided to get LS3 valve cover just that side. Solved
Coolant (steam) cross over for new LS3 heads. Back is plugged, so my stock LQ9 crossover fits, Use to go into throttle now it cant. People are saying plumb it into radiator at highest point?
Lastly is PCV system: read the best way is to buy a LS6 valley cover since I can install back my knock sensors in it as well, it has a opening that you can run left side outlet on LS3 intake to the valley cover then run the top TB outlet to the passenger side valve cover, then plug driver side back vent on valve cover. or should i plug driver side valve cover outlet to driver side outlet on intake.
Like i said i got easy part over, I am not familiar with LS3 setups just yet. Been doing research but usually get good advice on here.
Thanks
