Cutouts and maf delete? Straight answers?!?
Old Oct 21, 2015 | 02:54 AM
veezee's Avatar
Default Cutouts and maf delete? Straight answers?!?
I did a search but couldn't find the answers I was looking for. Sorry if this has been covered before and if so please provide links!
Ok, so I have an l76 6.0 which has headers, high flow cats and stock (super quiet) catback which I like so I don't draw attention to myself. I also have dual 3" cutouts just after the cats.
I have a 102/102 intake combo and the standard maf was too small so it's sitting on a shelf. It's been tuned without the maf, but with the cutouts plated up (didn't have electronic cutouts at the time) I can get a 100mm maf if necessary.
I heard recently that with the car tuned with them shut, if I open them my car will run dangerously lean, and if I get them tuned open it will run too rich with them shut.
1st, is that last sentence accurate? Is a maf necessary to get the most out of cutouts both open and shut?
2nd, can I get away with tuning them open and just deal with running rich when I go cruising with them shut? Or should I get the 100mm maf and get it tuned that way?
Thanks for the advice! (And let me know if I have my info all backwards lol)
Old Oct 22, 2015 | 03:24 PM
veezee's Avatar
Nobody has experience with cutouts and speed density tune? Maybe I should have posted this in the tuning section
Old Oct 23, 2015 | 10:33 AM
redtan's Avatar
Depends on where you put the cutouts really...but opening them up shouldn't have too much effect on fueling. In your case, the cutouts being relatively far away from the engine and collectors and past the cats would fall in that category.
It might appear lean to the 02 sensors, but that's most likely from fresh air contamination if you have them placed near the sensors. But again that shouldn't be the case in your situation as they are plenty far away from the sensors so they should still get an accurate measure of the mixture.
Old Oct 24, 2015 | 07:48 AM
veezee's Avatar
Thanks for the response,
I was more or less under the impression that it wasn't so much the o2 sensors misreading but the change in backpressure from restrictive to high flowing yet without a maf the motor doesn't know to add extra fuel.
Anyway, I'm getting an e85 retune at a later date I'll just not use the cutouts until then.
Old Oct 24, 2015 | 09:10 AM
redtan's Avatar
Again that difference is very minor, especially where you are putting the cutouts. If you were putting them before a huge restriction (eg. before stock cats) then that would probably affect fueling somewhat. But you are putting them relatively far away where it's not going to make that huge of a difference if at all.
Think about how an engine works. Fresh air enters the manifold, gets mixed with fuel, goes into the cylinder and then out the exhaust. So regardless of what you do to the exahust, if you don't make any changes to the intake side of things you're not going to allow more air in the cylinders thus needing more fuel. You can have the most free flowing exhaust in the world, the amount of air entering the cylinder will be dictated by the intake side of the engine (air filter, tube, intake manifold, head runners, intake valve etc.). Changing the exhaust is not going to magically allow more air into the engine if the same restrictions are present.
The reason you see gains from exhaust is not necessarily from more air, you just lessen the restrictions thus the engine doesn't have to work as hard to pump out the exhaust gasses thus it becomes more efficient.
Old Oct 25, 2015 | 08:06 AM
veezee's Avatar
That's some logic I can understand thanks! I appreciate it. I guess I am just a paranoid person lol. Better to ask a dumb question then make a dumb mistake right!? For what it's worth the cutouts are about 18" and 6" away from the front and rear o2 sensors respectively on either side so hopefully that is indeed far enough back to not change anything. Thanks again.
Old Oct 26, 2015 | 05:01 PM
GSAWYERS's Avatar
On an SD tuned motor, you're still using the MAP sensor to know how much air is coming in. As long as the car is tuned properly, it shouldn't have a problem dealing with it. Dyno tune it with the cutouts open, then street tune it for driveability with them closed. If you have a good exhaust, the open/closed difference probably won't be that much.
