Need an adjustable alternator bracket
Old Oct 25, 2015 | 08:11 PM
Redfire LS's Avatar
Default Need an adjustable alternator bracket
I have a 6.0L and I want to run a high amp aftermarket alternator, the only problem is the alternator mounting holes don't line up with the bracket. I was wondering if anyone had any suggestions or knew of a place where I could get an adjustable bracket? I'm not running the idler pulley or the power steering pump and I've already cut that section of the bracket off, so I just need something to bolt the alternator in place.
Attached Thumbnails Need an adjustable alternator bracket-img_7270.jpg   Need an adjustable alternator bracket-img_7269.jpg
Old Oct 28, 2015 | 05:53 PM
CBM Motorsports's Avatar
Looks like you got an alternator for a Corvette. They have a wider bolt pattern. You need one for a 4th gen Camaro. They have the same bolt pattern as the truck bracket. We have them in stock for the 250 amp version. No modifications would be needed at that point.
Old Oct 29, 2015 | 08:32 AM
Redfire LS's Avatar
Yes it's an LS3 alternator and I already have the stator plug on it switched so all I need to do now is get a bracket for it, I'm trying to avoid having to buy another alternator. Someone must make something that will work? I suppose I could see if a machine shop can make one.
Old Nov 3, 2015 | 06:25 PM
If you don't mind moving the alternator to a stock 4th gen F-body location, I have a bracket to work with your alternator.
