LSX 427/4.0L whipple build.
I am I desperate help on the computer and harness I need to use to get this thing to run as a daily driver but also have the 1k Hp when ever I want it. Now I know it will need to be tuned on a dyno and all that good stuff, but if someone could point me in the direction of a computer system and harness that will work for me It would be greatly appreciated! This motor is going in a 96 Silverado. And yes, it will still have a/c power steering and all that good stuff. I would still like to use cruise control and power windows and that good stuff but also not have to worry about service engine lights coming on 24/7. Please guys, I know y'all can help me and I'm In need.
Also if you bought a 2500 series truck it would have a 4L80E trans already. The internals of a 4L60/4L65E look like twigs compared to a 4L80E. In addition if you bought a 4wd truck.... it would be able to actually put the power down on a normal "street" tire. The front/rear differentials are also much beefier in a 2500 series truck.
If you want reliability... you don't want 1500 series wimpy parts.
Let's value your Silverado at $1K.... even if you bought a $6K newer truck with the correct parts from the get go.... you would be saving a ton of money in the outcome. A 4L80E with a shift kit can handle big power.... a 2004.5+ LS motor has the better LS2 rods... that people are pushing 900rwhp thru.... stock motors with upgraded cam, LS9 head gaskets, head studs.
