Looking for ls3 recommendations
Heads? Cams? Intakes?
If you're looking to go with a basic LS3, there's no better start you can go with than a GMPP Crate motor because it'll have pretty much EVERYTHING you need short of the accessory drive and the PCM.
http://www.chevrolet.com/performance...gines/ls3.html
You can also call these guys and see if they can help you with the conversion.
http://www.brphotrods.com/
KW
Not sure BrpHotRods is around, left them many messages and emails, never got any answer... maybe they went on vacation for a month....
Although, if you're talking about 600 crank hp, you won't need bother with the bottom end.
