LSA boost reference for fuel pressure reg?
Old Mar 20, 2016 | 06:58 PM
SmashBox's Avatar
Default LSA boost reference for fuel pressure reg?
Hey guys.
Where abouts do I pull a boost reference from for the fuel pressure reg on a LSA?
Old Apr 5, 2016 | 11:11 AM
stevieturbo's Avatar
If you have built a fuel system that can use a boost reference, anywhere between the blower and intake valves. If you've a boost gauge fitted, the same line would do.
If you change from a system that was not boost referenced to boost referenced, obviously your ecu will need re-tuned to suit.
