5.3 Aluminum Identification
Old Apr 27, 2016 | 06:05 PM
Roofnuts's Avatar
Question 5.3 Aluminum Identification
New guy here looking for a bit of help. I picked up a 2009 5.3 that had 70xxx miles out of a silverado and a 2012 4l65e for 700 bucks last night but i cant tell exactly what block it is. Ive done some research but im still not for sure. It has VVT, DOD, and the white 58x reluctor sensor on the passenger side of the block and 243 heads. Also i was wondering who i should go through for a wire harness, the engine did not come with one. I plan on dropping it in my 85 c10.
Any input would be helpful.
Attached Thumbnails 5.3 Aluminum Identification-20160427_165937.jpg   5.3 Aluminum Identification-20160427_165924.jpg   5.3 Aluminum Identification-20160427_165649.jpg   5.3 Aluminum Identification-20160427_165712.jpg
Old Apr 29, 2016 | 03:26 PM
Civicsr2cool's Avatar
If that sticker on the block has the vin you can check which version it is by decodi the 8th number. That's as far as my knowledge goes!
To vin check use this : https://service.gm.com/dealerworld/vincards/
Old Apr 29, 2016 | 07:01 PM
Roofnuts's Avatar
Thanks for the input, I'm going to assume it's a lc9 as there is no vin on the block
Old May 3, 2016 | 04:58 PM
Project GatTagO's Avatar
It has an aluminum block, so you don't have many options. It isn't a LH8 because the LH8 doesn't have VVT or AFM....So being a LC9 is the only other option I believe.
Andrew
Old May 19, 2016 | 02:32 AM
07NBSChevy's Avatar
How do you have a 2012 4L65E when they were only installed in vehicles from 2001-2006? Even the 4L70e was used from 2006-2009. You sure you didn't get a 4L60E?
Also, VVT was not an option until 2010 mid year model year trucks with the 5.3. It does have AFM/DOD, all 5.3's from 2007.5 to current use AFM/DOD in Silverados. The engine is an LC9
Gen 4 engines, all use aluminum heads.
The LC9 is a flex fuel, aluminum block, AFM/DOD and started production mid year 2007 and used in 4WD truck only. Same as LH6, just with flex fuel.
The LMG is a flex fuel iron Block, Same as LY5, just with flex fuel. This model is known the have the least amount of issue out of all Gen 4 engines.
The LY5 is a non flex iron block, Same as LMG, just without flex fuel
The LH6 is a aluminum block and was only used in 2005-2009 GM midsized SUVS
The LH8/LH9 is a non-flex aluminum block and only used in the H3 and Colorado
The LMF is a iron Black and doesn't have AFM/DOD or Flex Fuel and was used in Vans only
The LS4 is a aluminum block used in cars only
VVT was introduced mid year 2010 model trucks in the LC9, LMG, LY5 and (LH9 for H3 and Colorado).
The LC9, LMG and LY5 were the only 5.3 options from 2010-2013 in Silverados.
4L60E was used from mid 1996 to 2013, 2010-2013 used only in 4.3 and 4.8 Engines
4L65E was used in all GM Trucks and SUV's using the 6.0 engine from 2001-2006(2007 for the Silverado SS and Denali's)
4L70E was used only in the TrailBlazer SS from Mid 2006-2009
Just thought I would throw this out there. Probably info that is not needed lol.
