LS3 Map Sensor Help...
Old May 3, 2016 | 11:00 AM
nicke's Avatar
Default LS3 Map Sensor Help...
Hey Guys, I picked up a 2014 L96 engine for a swap and it has an LS3 intake, on it (fuel rails and injectors too). It didn't have a map sensor, so I'm trying to figure out which one I need. The engine will be NA, and I haven't purchased a wiring harness for it yet, so I'm not concerned yet with the connector.
Anyone have a part number for what I need? I see 1 bar, 2 bar, and 3 bar, but am unsure what that refers to and what is needed.
Thanks
-Nick
Old May 3, 2016 | 08:35 PM
slogo's Avatar
I am not an expert, but I think the 1 Bar represents 1 atmospheric pressure 14.7:1
2 Bar represents 2 atmospheric pressure 29.4:1
and 3 the same
Cannot explain because I do not know, and I could be completely wrong, but thats a start to do some research on
But I think I know if you are not forced induction you only need 1 Bar.
If I am wrong someone will correct.
Old May 3, 2016 | 09:49 PM
one fast zo6's Avatar
Hi everyone not to jack but I need a 2bar map that fits the fatory ls3 intake with 2000 camaro map pigtail.
Old May 3, 2016 | 11:42 PM
nicke's Avatar
Thanks.
Can someone confirm that a 1 bar map sensor will work for my na application?
Nick
Old May 4, 2016 | 11:28 AM
weeble1's Avatar
I can't speak to your specific application, but I can tell you that in my Trans Am, I had an LS3 map on the intake in my LY6 swap and the car ran like crap as it wasn't tuned for it. I then swapped out my old LS1 map and used a o ring to seal the hole and the car ran 10x better and didn't have issues idling. I know a lot of this has to do with tuning for the other map, but if you are using an LS1 harness/ecu, the LS1 MAP should do what you need, especially if you are staying N/A.
Old May 4, 2016 | 12:57 PM
nicke's Avatar
The ecm is an E38, and I haven't purchased a wiring harness yet. I'll obviously have a tune done once I get it going. Can I just put in any 1 bar sensor that will fit?
Anyone have a part number?
-Nick
Old May 4, 2016 | 07:36 PM
slogo's Avatar
If it is a LS3 intake manifold get one that fits the intake manifold, find out what car came with LS3 engine and get that one.
If you are going N/A don't worry about Bar
I'm not trying to be a dick here, but if you are going to tackle a swap you need to learn how to research for yourself, you might learn something.
Old May 4, 2016 | 10:34 PM
Crf450r420's Avatar
Stock one.
Amazon.com: ACDelco 213-4681 GM Original Equipment Multi-Purpose Pressure Sensor: Automotive Amazon.com: ACDelco 213-4681 GM Original Equipment Multi-Purpose Pressure Sensor: Automotive
 Michael S. Palmer
Old May 5, 2016 | 10:43 AM
nicke's Avatar
That's what I needed to know! Thanks!
-Nick
Old May 5, 2016 | 10:46 AM
nicke's Avatar
Thanks for the input. My confusion came from seeing all types of different sensors, and not knowing which I needed, as my intake didn't have one. Then I see a bosch vs delphi, which looks to have a different pinout.
I have already tackled a swap (truck intake that already had a map sensor in it), which you would see if you would do a little research. The condescending part of your reply wasn't necessary.
-Nick
Old May 10, 2016 | 03:29 PM
cwalsh's Avatar
The pin outs are different on on an LS3 senor to the LS1 sensor. Also if its not tuned/scaled for the LS3 sensor it will run poorly. I had mine changed in the tune before starting the car.
Chris
