lsa rods on l92?
Old Jul 12, 2016 | 11:42 PM
ricardo.benin's Avatar
Default lsa rods on l92?
Hi I have a l92 and I am in the middle of rebuild, anyways I have mahle forged pistons with stock pins and stock l92 rod length. Anyways my question is this, can I use a stock lsa rod with these pistons?
Thanks
Richard
Old Jul 13, 2016 | 07:44 AM
redtan's Avatar
Stock rods are 6.098" long, and most aftermarket pistons are usually made for a 6.125" long rod.
So you need to figure out what rod length the pistons were made for.
Old Jul 13, 2016 | 06:00 PM
The pistons are made for a stock rod and pin.
Here are the specs
Technical Specs:
Cubic Inches: 377
Bore: 4.070"
Stroke: 3.622"
Rod Length: 6.098"
Compression Height: 1.340"
Pin Diameter: 0.945"
Crown Volume: -4cc
Weight: 448g
Compression Ratio @ 70cc: 10.1:1
Old Jul 17, 2016 | 10:18 PM
427 zeo6's Avatar
Yes you can but for $500 territory you can get better lighter forged rods from Manley or other supplier.....the factory PM rods are OK but, they aren't anywhere near as good as a well done forged Rod.
