What size TB can I use?
Old Oct 11, 2016 | 05:30 PM
killingsworth73's Avatar
Default What size TB can I use?
Stock 2008 Corvette LS3. What is the largest size tb I can go without having to change injectors? Do I need to tune it with any d8fferent size?
Old Oct 11, 2016 | 05:32 PM
Aaron at SDPC's Avatar
Leave the stock throttle body on there. Its capable of supporting a lot more horsepower than that car produces stock. Also any time you go to a different size throttle body tuning will be required.
Old Oct 11, 2016 | 06:25 PM
Thanks. Asking for a friend
Old Oct 12, 2016 | 02:43 AM
American Heritage's Avatar
You can put a 102 on there if you want.
Will you need to tune? yes if you dont want it to run poorly.
Will you gain power over a ported stocker? probably not.
Old Oct 12, 2016 | 10:47 PM
KW Baraka's Avatar
Agreed.
At most, go with a V-max throttle-body (Google it). Otherwise.....stick with the stocker.
KW
