HARMONIC DAMPER-which one?
Old Nov 26, 2016 | 02:22 PM
Double J's Avatar
Default HARMONIC DAMPER-which one?
Hi, has anybody installed this one (powerbond SFI) as a budget friendly alternative to the very expensive ATI Super damper? If so did it meet your expectations? Thanks in advance
http://www.speedinc.com/shop-by-vehi...l#!prettyPhoto
Old Nov 27, 2016 | 07:08 PM
Double J's Avatar
BUMP for help.
Old Nov 29, 2016 | 03:47 PM
Double J's Avatar
BUMP for help
Old Nov 29, 2016 | 10:19 PM
BODUKE's Avatar
I have a powerbond it is fine.
Old Dec 1, 2016 | 09:42 PM
Double J's Avatar
Thank you, which one are you using , underdrive?
Old Dec 3, 2016 | 08:18 AM
BODUKE's Avatar
25 percent pulley
Old Dec 3, 2016 | 03:10 PM
KILLERARMY's Avatar
I went with a ATI 10% W/AC balancer when i was on a stock motor with Trickflow heads and cam.Now i have a much bigger motor (435ci) and LS7 head.I had to shipped my ATI balancer back to them for them to upgrade the rubber to 60 durometer.The second choice for balancer would be Innovator West balancer.
Old Dec 11, 2016 | 01:13 AM
Nathaninwa's Avatar
I have a powerbond 10% underdrive. Only issue I've noticed is once the truck alternator heated up it would quit charging around 700 engine rpm. I now have the dr44g installed which the Ecu controls and it's all fine cold or hot
