Hi-ram 4th Gen filter relocation
Old Dec 1, 2016 | 01:31 PM
cheston11's Avatar
Default Hi-ram 4th Gen filter relocation
Everything is on the car but I want to run a intake or get this one fixed up right. my plan was to relocate battery and run the filter there for now. if I can, it would be nice to keep the functioning ram air. anyone run an NA setup hi-ram? what did you use to run factory air box or where did you run the filter? I plan on going turbo in 6 months or so. so, I don't need to spend too much on it. it's a speed density tune currently, so no MAF. it currently has AC components but that is going away with turbo build.
Old Dec 1, 2016 | 02:36 PM
Mikey 97Z M6's Avatar
If you ditch the ABS unit it's pretty easy to route it to the driver side behind/under the headlight area.
