2007 escalade 6.2 liter cam swap
Old Jan 25, 2017 | 12:29 AM
Warren Conner's Avatar
Default 2007 escalade 6.2 liter cam swap
Has anyone swapped out the factory VVT Cam for a slightly more aggressive non VVT cam? If so when it came time for tuning what all was needed to be changed? I'm using Hp tuners
Old Jan 25, 2017 | 07:47 AM
JoeNova's Avatar
Restricted User
Why not keep VVT? They make some awesome VVT cams.
Old Jan 25, 2017 | 03:04 PM
I have taken vehicle to dealership numerous times ad they could never fix the service stabilatrack and Traction control MILS. So after changing everything I could think of besides the cam to fix it. I decided to change the cam and delete the vvt. This is also what comp cams recommend
Old Jan 26, 2017 | 09:00 AM
JoeNova's Avatar
Restricted User
VVT won't have a single thing to do with your problem.
If you have working VVT, its just a bad idea to get rid of it. A good VVT cam will outperform the same cam without VVT.
