E38 Standalone diy?
(This is for a an 07 5.3 with afm and 4l60e)
i used this site for wiring
http://lt1swap.com/2010camaro.htm
Edit: I see you have a 2007 motor and I assume the ECM is the same year. If so I would order a throttle pedal from a 2007 model to be on the safe side. The E38 ECM changes a little over the years.
(I think I found my answer. That ties into the bcm. I am just going to delete those wires and if it dosnt charge sounds like I can get an earlier alternator)
